Mapping HELP for GO 630
GO 630
Hi guys .. I'm very new to GPS .... I drive a tractor trailer through Canada and I'm trying to program a route into my new GO 630. My problem is that the unit is always routing me through the US. Is there a way to have my routes to always go through Canada ONLY.
OR
Can I remove the US maps in the unit ?
Thanks for the help
You can't eliminate the US portion of the map. You might try as a restriction to Always Avoid Toll Roads as a planning restriction. I think all bridges to the States cost $$$ and the TomTom considers them as toll roads.
Try that.
Another one-at-a-time solution is to erase all the border crossings via mapshare. Just don't share it with others.
