- Joined
- Dec 27, 2008
- Messages
- 9
Hi all,
A question with map corrections. I am adjusting some speed limits, on the Australian map, in near by areas. I am not having a problem with doing the changes, HOWEVER, sometimes the sections of the road dont exactly match up with the relevant speed limit change points. When changing the speed limit, it will match a section of road. Where there is an intersection, the section of the particular road starts or stops at that intersection, no problems. On a long sections of road, the road is broken up sometimes in smaller sections, not always, again not necessarily matching where you may want to change a speed limit. I have tried adding a poi at the relevant point of road, to try and break the road section into a useable piece for a speed zone. But these added pois don't break the road up at that point.
Is there a method of breaking up these long road sections, so one might be able to change the speed limit at the correct point, and not relying on the sections of road tomtom have used???
Jeff
Jeff
