I've had my GO 720 a couple of weeks and thought everything was fine. With App Ver 7.221 and N_A 710, the voice recognition was working, the text-to-speech was working. I'd spent many hours correcting local POIs.
In the unit the app version was 7.221, but on virtual TT the version showed as 7.220. (I figured I actually had ver 7.221, since the voice recognition worked.)
The map version on the TomTom was 1239.8 MB, and the version on the computer was 1723.1 MB, which I figured was more detailed. So I tried to copy the larger map to the TomTom, after removing the map from the unit. The larger map wouldn't copy - lack of space - I needed 330MB additional space (and there was less than 100 MB on it.)
So I copied the smaller map (1239.8 MB) back onto the TomTom, and it was version 705. Then nothing worked! The map display was gibberish and filled with red and yellow lines; the text was gibberish - no language I recognized.
"Update My GO" told me there was a newer version of the application, so I downloaded it; it was version 7.220.
I tried "restore" several times; I tried the reset button several times. I've tried several times to copy version 7.221 from my computer to the TomTom, and I've tried several times to copy map ver N_A 710.
Nothing has worked, yet. I don't know what else to try.
ANY help will be GREATLY appreciated. (Please don't make me have to contact TomTom Customer Support - you guys know more about this than they do... plus they have simply not responded to my last two emails.)
