looking for a car charger
Melbourne FL
Tom tom One
Hello all -
I am looking for an additional car charger for my TT One.. I use this in my car and on my motorcycle and I would liketo hard wire a car charger unit into my bikes battery...
The Tom Tom site does not list one being available for purchase.
does anyone know where I might find one for sale??
Larry,
Have you tried seaching ebay or buy.com?
I know you will get many search results from ebay
Hi Larry,
I don't have an answer for you, but I would like to know how you mount your ONE on your bike?
Hi Fanchee -
Mounting on the bike was not that hard once I did a little research..
It is basically 2 pieces.. The first is a mount that attached to existing screw holes on the left handlebar instrument pod. This attachment has a 4 hole mounting base - which is pretty much universal.. I purchased it from a company called Tech Mounts
Once I had that I found another company called Pro Clips that sells mounting gadgets for automobiles. They had a mount that was designed for the TT1 and has the same 4 hole mounting setup (universal is good!!)
Here are a couple of photos - one showing the mounting setup - GPS mount.jpg
and one showing the TT1 attached
The other mount that you see in the first photo is for my XM radio..
And I have solved my car charger issue.. The same Pro Clip company makes a mount that has a charger built into it. When you slide in the TT1 it attaches to a USB in the bottom of the mount. From there I can wire the other end into my bikes battery and I will be all set..
Motorola Razr cell phone charger will work with your TTone. I've been using it for about a year now with no issues. They are available at any cell accessory store including staples, best buy, radio shack, etc. Its a very popular phone.
Christoffel
