Have a new 910 and still trying to figure out how to most effectively find and navigate to POIs. Does any one know of some tutorials or threads specifically about POIs?
For instance, if you have categories of POI set to display along your route, is there no way to find info on the displayed symbol - i.e. what restaurant is the symbol referring to?
If you look up a POI on "browse map", Starbucks for instance, it will list several but it seems you have to select only one to display on the map, can I not somehow display more to get a visual idea instead of just the distance (the distance does not tell me which direction it is).
Even if I do select one and it displays, I haven't found how to then navigate there without going to "navigate to" and going through the whole list to find the POI again. That doesn't make sense.
