Go Camper Max
go
So I have desided on a Go camper max for use in ower motorhome but can anyone tell me the difference between the Go Camper Max and Go Camper Max 2nd gen?
How do you know it's a 1st or 2nd generation?
It seems to me that the 1st generation should no longer be available for sale.
The only difference in price is the more or less options on the models.
Both still listed on a well known site
Am I allowed to add link to said website?
perhaps the USB connection is different? I had a camper max (using micro usb) but traded it for the go exclusive (which has an usb c connector, as well as more features).
Maybe it was the GO Camper Tour (same model as the Max) that you bought that doesn't have a USB-C jack?
Doesn't the new 7" Camper Max (2nd Gen) now have alerts when you drive into a low emission zone etc?
williamarnold
