GO 730 distance calculations and more??
Australia
GO 730
I have a couple of questions...
I know it shows the distance from where you are to the "navigate to" point, but is there somewhere on the 730's that shows the distance you have actually travelled???? For instance; If I wanted to see how far I travelled on "Tuesday"...
Also, is there a way of adjusting the VC distance??? My father in laws "one" has an adjustment in meters for the commands, but cant find it on the 730...
As far as the distance you've travelled and stuff like that, see the link here for a 3rd party application, Tripmaster, that now works with application versions of Navcore 8+
VC? Not sure what you mean.....if you mean computer voice to speak 'metric', Preferences-->Set Units (page 5).
My American computer voice, Susan, gives distances in metric measurements.
If you mean something else, please clarify.
After you for example you navagate to some poi. Press details before in goes to driving view. Then go to Browse as text. Then go to options on the bottom and finally put the dot on distance since departure. See if that helps you. Good luck I have the 920 but it should be the same with your unit.
Thanks for the link, I'll look into it...
VC Distance... Sorry, I should have explained a little different/better...
For example, If coming up to a roundabout, the VC warns at, say, 600meters before that roundabout. On my Father in Laws "one" you could set this distance. Is this possible with the 730?
Look at the options under speech preferences for warnings, if I remember correctly.
Thanks for your reply.
Unfortunately I cannot find any option to change the distance. There is only "tick" boxs for other options.
