Droopy mount?
http://www.tomtom.com/products/accessories/accessory.php?ID=370
I have this mount with a ONE 3rd edition.
The problem? I've been noticing that when I drive, especially on bumpy roads or areas with speed bumps, the TomTom itself lowers its viewing angle slightly. After several minutes, I go from having a straight-on view of the screen to the screen being aimed at my chest.
- Is there a way to stiffen the ball-and-socket joint?
- Is there a superior mounting solution? I'm hoping for something less permanent than ProClip.
- Finally, is there anywhere I can order the mount alone without a power adapter? If the mount truly has this problem, I'll just buy two or three. ;-)
My wife and I share the entire unit, mount and all, between two vehicles. We remove the device when parking, mount and all, to make the car look less enticing--our city has a pretty serious crime problem.
Thanks!
I think I just answered my own question. I just found a hairline crack on the socket of the TomTom mount. So there's my drooping problem.
I still need to know: can I buy the mount alone?
Yes, the Akron is an excellent mount. I've had mine now for about 6 mos. It's never failed, has detents so when the knob is tightened, locks in positively. Also has a swivel head so you can tilt it to driver if you want.
It's still on sale at Semsons.com for $10. Here's a picture and link:
semsons-inc_2037_13336528
http://www.semsons.com/miwipewiswti1.html
