Is there any way to get a working calculator onto the 720?
Would be useful for fuel mileage computations. 720 used on a motorcycle, so it would be easier if the calculator was on the device rather then carrying something separate in a tank bag, etc.
I would liek this on my One too, would be nice for MPG and for tip calculator etc.
Try this:
http://gps.dg4sfw.de/files/calculator_33.zip
05.05.07 (b33) Now also works on TomTom One v2 and v3.
I believe the reason it does not work has to do with the NavCore 7 firmware. The decision TT made to discontinue the SDK will likely cause trouble for 3rd party developers.
You can try emailing the author and she what he/she can do - (e-mail address removed)
the reply..
Yes, there will be a Calculator for v7, I am doing the necessary preliminary work at the moment, but unfortunately it will take me some time, since I am moving at the moment, I hope to be able to fix it 'till spring next year.
so likely in the future![]()
Loaded the calc, mpg, blackout and flashlight last night...everything works on my TT1 V4. I'll have to play around a little more to see if I keep it all but as a side note does anyone know if there is a max number of menu pages? It seemed the TT wasn't happy when I had 6 so I removed the Mobilnova trial app and everything was fine again. Could have been a conflict but I don't know???
Is there a running list somewhere of all teh apps available? I have quite a few but always seem to find more and I can't help but add them even if I don't think I will use them.
The Calculator works fine on my 720
Thanks![]()
(b36) Now working on TT-"Firmware" 7.x and (hopefully) ALL TomTom PNAs.
Thanks![]()
