Battery Replacement For Go 630
Winnipeg
<img src="/styles/default/custom/flags/ca.png" alt="Canada" /> Canada
Via 1535 TM
I did a search for a tutorial for the battery replacement for Go 630. There seems to be tutorials for a lot of the other models but not for the Go 630.
Any information would be appreciated.
Given the general construction appearance, I'd go with the 720/730/920/930 instructions and see how those play out for you. The battery is the same one that is used in those models.
See the top "Sticky" in the TomTom Tweaks section.
Sorry, I forgot to ask you previously : Does replaceing the new battey loose all the information you have on programmed on your TomTom?
Nope, it does not.
That said, never hurts to make an Explorer backup, just in case.........
Seanbt
