Can anyone help? Before I came on vacation I used the RouteConverter software to plan my own trip. I converted and added to my ITN file. It worked flawlessly. Now I try to plan my return to home route and discover RouteConverter has stopped working with GoogleMaps, There now has been RouteConverter 2.0 released. It appears to work, but here's the problem. Once I put it in the itinerary it appears fine. But when I let it load the route, then look at the details in text, it doesn't match the itinerary! It adds steps and turnarounds that I didn't add and unnamed roads. It also adds miles of course! Is there something to fix this problem? I want to follow my routes--with TomTom's help! AGAIN--it converts OK and apears OK in the itinerary--but when loaded and check details it does not match!!
Help
Help
