The 3.5 mm connector on our Go920 has broken. I suspect from repeated vibration and plugging in and out one or more of the connectors broke loose from the circuit card but I did not try to open the TomTom.
I am hoping to find an inexpensive 3.5mm bluetooth headphone receiver. I have seen a video on YouTube that shows one that apparently works with the TomTom but I live in USA so it would be easier to buy from a store shipping in USA. I found more expensive models but hoping to find a less expensive model preferably less than $25.00, more importantly, I prefer to know it works with the TomTom go920 before I buy it.
YouTube - 3.5mm bluetooth headphone receiver
Prior to this idea, I purchased a refurbished 730 to replace the 920 on the motorcycle, and planned to use the 920 in the car only - but if I can get the 920 working again with our intercom, I will put it back on the motorcycle, and give my wife the 730 for her car.
thank you in advance, just in case I can't respond to any posts as quickly and often as I should
joe
joe
