2amp Car Charger Fuse?
My car adapter blew a fuse. It is a 2 amp mini blade. Does any one know where I can get a replacement? I called radio shack and a couple auto zone type stores and the smallest they had was a 3amp. There are a couple online stores but given shipping costs it would be about $2/fuse. I did order from Amazon but they sent the wrong part and actually have no 2amp fuses. If you have purchased these fuses where did you get them???
I did a quick Google search for "2 amp mini fuse" and it said Ace Hardware carries them. In addition many on-line sources. You can use a 3 amp until you find the 2 amp or order one. Personally, I would just use a 3 anyway. Not enough difference there to cause you any real issues.
Good Luck
Bob
