Hi guys,
I'm hoping that I can explain what kit I have and what I hope to do and you can then tell me exactly what else I need to buy to make my Tom Tom life complete.
I use a Mac Mini Aluminium computer running Snow Leopard.
I have just received a parcel from eBay containing a Tom Tom Go 630 unit, in-car charger, screen mount and a dummy SD card in the slot. Nothing else. This is exactly what I was expecting because the seller was very careful to make sure that I knew what i was buying.
I have since ordered a mains charger and a desk dock unit with USB lead to connect unit to Computer. Those last 2 should arrive by the middle of next week or sooner.
Please note that I do not have any software except for whatever is needed to make the Tom Tom Go 630 T work which it does perfectly.
I would like to be able to connect the Tom Tom unit to my Mac PC in order to add voices, POIs, Safety camera info etc. I would also like to remove all maps except the map of the UK.
Any info as to what I need to make my life complete will be gratefully accepted but if all you can do is help with my Tom Tom question, that will also be received with heartfelt thanks.
Steve
Steve
