I have a Tom Tom One XL and after I set my trip and get started on the road, the time remaining always shows about double what it should be and therefore the arrival time is later than it should be. I usually travel about 60-70 mph so if the distance that I have to go is about 120 miles, the time remaining will show about 3.5 hours instead of 2 hours. It is almost like it is calculating the time with a default speed of 25-30 mph. Even when I get within 5-10 miles of my destination, it still shows about twice the time. I have downloaded the latest software and this has not helped.
Anyone know what the problem is here?
I have not found a way to reset the default speed setting. I thought that it was supposed to adjust the arrival time according to how fast you were traveling. Not so?
