How do you get the suction cup to hold? I have a tt1 XL and it won'y stick very well to the windshield or the dash plate.
I usually add some moisture to the cup, that works. Saliva works best!![]()
Has anyone found a "sand bag" holder for the TT1 for the dash? For as much as I like the vent holder it seems like the AC or heat will kill the unit..
Thanks,
Jim
Just a follow-up. These vent mounts kick major butt.
Blocks about 2/3 of your vent but overall absolutely no complaints!
