Device: TomTom 720
Purchased: 1.5 years ago
Map Version: 5 quarters old...
Map: US& Canada (2GB) 7.10
Introduction:
I want to have a new map, but since the 2GB map is now maxed out, I've been looking at the NE Region map (I live in NY). I have read in other posts that the 2GB map isn't as detailed or as complete as the newer and larger North America map for newer TomToms. So instead of upgrading my North America map for $50 and then paying another $50 for a year of updates to a map that isn't going to get any larger, I'm looking at buying the NE Region map.
I don't plan on traveling out of the NE region as my car simply isn't reliable enough to do so, even if I wanted to. So for $60 I think I'll just buy the NE region map and then another $50 for a year of update service.
Question: So if I wait until after the May map comes out before buying the NE Region map and a subscription, I will get more out of the subscription, right?
Question: If I put a 4GB SD card into my TomTom 720, could I buy the complete North America map that is on newer 4GB TomToms and install it? I know HOME doesn't give me the option to buy the bigger North America map, but it appears TomTom's website does.
Question: Is there any reason they would cripple the NE region map to a smaller size? ie: Do you think it will be "limited" just like the 2GB USA&Canada map became?
Thx for your input.
Introduction:
Thx for your input.
