Hi from a newby and help
Hi, just updated my maps and have no memory left to play with. I bought an 8gb SD card today but I cannot get the backup to restore to the SD card. I followed the instructions on the help page i.e. put device on without memory card and create backup. Then insert card and restore backup which should automatically go to the memory card. The backup just goes to the device memory
Heeelp.
If I understand you correctly, you didn't run out of room, but you're right on the edge? And you were trying to use TomTom Home to move the map?
If that's the case, you can hook up your TT and just copy the entire map folder from internal memory to the SD card using whatever normal file copy method your PC's OS uses (instead of Home), then delete it from the internal memory. Not knowing what device or map(s) you are running, all I can tell you is that the map folder will be in the root of your TomTom and should make some obvious reference to the countries (North America, Western Europe, etc.). To your PC, your TomTom looks like two external disk drives now that you have the SD card installed, so you'll have to look and identify both the internal and SD.
Before you do anything, we always recommend you make a full copy of your TomTom to your PC's hard drive, too. Now that your map will be on your SD card, you'll want to be backing that up to your PC's hard drive as well once you're done.
Your understanding is correct. I am copying files now as you suggested and will get back to you. Thanks very much.
BTW maps are Western Europe
Regards Ken
A dutch newby 1
Custom POI questions (newby) 4
Live 1005 newby 3
Hi, stressed out newby 3
newby from Florida 6
Newby signing in 5
Australian in Germany - Newby 5
newby, bluetooth problem,any help out there. 6
