I have just returned from Rhodes after buying and using the Greece Map.
Map worked as expected. What wasn't expected was TomTom's tendency to route you down minor roads. In UK thats not a major issue, in Rhodes it was!!!!
What start out as tarmac'd dual carriage ways frequently and rapidly turn to gravel tracks complete with ruts and water run off trenches crossing the track. After 10 miles I had to turn back after reaching a too deep gully.
I quickly learned to "find alternative route" and stick with the major routes indicated on the most basic paper map and all was well.
Only last stray was when I left my GO730 mount on the hire car window as TOM TOM dont seem to supply the short stem mounts any more. I've now ordered a copy off ebay.
If you're going to a Greek Island it might be better to say yourself the ?39.99 and buy a paper map !
