HI guys
hope someone can help me here I have a Go 910, which is not charging. The Green charging light is on, but it does not charge either on the USB cradle or the car cradle. My questions therefore are this:
1) Is there a way to check if its the battery or the device?
I ask because i suspect that the problem lies with connection to the charging unit, as it has just started not charging and when its in the car and i hit a bumpy road it dislodges the unit and it switches its self off, again it's just started doing this.
I suspect it could well be the black quick release clip which holds it in place, as on closer inspection one of the lugs sticking out appears to be smaller/worn.
2) This being the case is it possible to buy parts from Tom Tom?
I ask as replacement of the said clip is really straight forward, apart from being spring loaded, which is meant to apply pressure to keep the unit in place and i suspect keep contact between the unit and the cradle to ensure charging and contact with external mic etc.
Many Thanks
Many Thanks
