TomTom GO, no audio through hearing aids
TomTom Go app installed on iPhone 12, IOS 17.5.1
Hearing Aids are, Oticon miniRITE R.
The Hearing Aids are paired to the iPhone (Bluetooth), the pairing means that all audio is passed from the iPhone to the Aids, eg phone conversations, music, etc.
However, despite going through options in the TomTom app no audio comes through from the app to the Aids, switching the audio from the Aids to the iPhone I get all the audio.
If I switch to the Google Map App instead, I immediately get the audio guidance through the Aids.
What if anything am I missing?
Not sure if Tomtom GO is compatible with Bluetooth you should try with Amigo which is Bluetooth compatible.
If as you suggest that the app is not Bluetooth compatible, why is it that when selecting, Settings, Voices, click on the default voice, the audio comes through my Aids,. Note, in the Instructions settings all options are selected.
Having contacted TomTom support, they confirm that the product will not work with any Bluetooth device. To get some audio from the app the user will need to disable Bluetooth on the phone, I confirmed this by turning off Bluetooth on my phone, and hey presto I get the audio from the phones speaker.
It strikes me that the lack of Bluetooth capability is not a technical but marketing issue/licencing issue. At the end of the day TomTom have decided to ignore those with a hearing disability.
I don't know what TomTom support mean when they say TomTom Go Navigation will not work with any Bluetooth device. I use TomTom Go Navigation on my iPhone or iPad with audio routed via Bluetooth to an FM radio device in a couple of cars that have no built in Bluetooth. Navigation audio guidance works OK.
Can you share where this was? Do you have an incident number? For me it works with Bluetooth headphones and a Bluetooth speaker.
This wasn't me. I don't have a problem. It's the OP who says TomTom support advised that TomTom Go Navigation will not work with any Bluetooth device.
Just checked this for you on TomTom go. I have minirite too. The hearing settings need be “always hearing devices”. Hope that helps although I find these settings have a mind of their own.
Fahad
