I have had a lot of invaluable advice on the forum and have managed to change all the speed limits which were incorrect on quite a long route in Australia. I have also copied all the files on my TomTomXXL 540 to my hard drive via Windows Explorer as recommended.
Two questions now
Firstly will this route with all its corrections work in reverse. I have corrected it on a trip from Adaminaby to Sydney, approx 600km. Now if I run it from Sydney to Adaminaby will the speed corrections still include my corrections? I realise II can run a Route Demo but that takes a long time if there is a simple answer.
Also relevant to this why it is so difficult to set the speed to run the demo. Does Tom Tom default to 500 times for a longer route because no matter where I tap the slider it bounces back to 500 even on a shorter route.
Secondly if I need to use my computer backup can I restore only the files relevant to this route with POI's etc or must I restore the whole lot and overwrite all my files.
Thanks for your support
Margek
Two questions now
Margek
