Hi,
New XXL 540 user here. I was playing with the map correction / speed limit function, and am pretty sure I entered some bogus data. How do I clear it out?
1. I assumed speed limits were entered as points, not entire road segments, and while I was trying to figure that out I'm pretty sure I ended up setting the speed limit to 45 mph for a whole series of broken line segments of the road, as I tried to figure out what I was doing.
2. Now I'm pretty sure my map on that section of the road is all mucked up, speed-limit-wise. The map initially had no speed limit for that road at all, and I would just like to restore it back to where we started, ideally by undoing or deleting the change I made.
3. When I try to re-select the road fragments, even when I find pieces set to 45, the interface won't let me delete the entered speed limit, it forces me to enter a value between 10 and (something big).
I didn't share the map correction, but am OCD enough to want it cleaned up off my unit. I guess I could delete the entire map directory and re-install it fresh...surely there is an easier way.
thanks.
thanks.
