Supposedly tries to route you by roads with speeds imbedded in the mapping data that don't exceed the value you input.
Truckers that can't use high speed roads or motorhomers (a.k.a 'caravaners') sometimes use that option.
That said, the route is only as good as the road data the map has. and sometimes that isn't accurate .......... I know, a shock!
That didn't work. I prepared a test route and it took me on "Belt Parkway", a road with 50 mph limit and I entered 40 mph as my limiting speed. So I ask again, just what does this routing option do?
That is what I thought. I assume that if I input say 40 mph here in the Metro NY area it *should* exclude the freeway/expressway/highway network.
So I think that some rules for road use have been programmed into the TomTom which are not the same as the speed limit for the road.
