Have you always been cursed with less than average battery life on your cell phone, and other devices that you have charging on your cig lighter??
Think about this, when you start your car, the battery takes a great drain on it.
If you have any electrical items (TT, phone,laptop...) plugged into the cig lighter, it is connected directly to the battery. Since there is no one way flow of electricity, when cranking the motor, the battery takes power where-ever it can get it.
Hence taking some power out of your phone, TT, etc on a rapid discharge, which most items like that are not designed to accept.
Soooo if you want to save your battery life on W.H.Y., do NOT have it plugged into the cig lighter!!!!
I've been getting almost 3 hours on a single charge. BTW
