help with 910 and music
I had my 910 up and going with music.
I then erased the music and reloaded it with more songs.
It says that it has 2gb music on the computer now but the 910 itself says it doesn't have any.
What am I doing wrong?
Please give us more information:
where exactly did you place the mp3 files?
Also try to do a soft reset.
The files are mp3. I tried several soft resets and tried loading several times.
Eventually I did a "restore" and all of the old stuff came back and the new stuff as well.
I don't know what happened or why but I like the results!
I believe you can use MS Windows Media Player 11 (or 10) to synchronize music w/ your TT; note this would be done outside TT Home...
Thats is true. If you open Windows Media Player 11 and you click on Sync down arrow you should be able to set it up. However, I haven't used it.
NOTE: WMP thinks my ONE is V3 :cool:
oops
I figured out why the music stuff wasn't working.
I wasn't waiting long enough. It would say that it found no songs. With waiting for about 30 sec or so it finds them. I wasn't giving it a chance.
Christoffel
