carry case for 720
Windsor - Canada
GO720
I posted this first on the 910/20 forum but its worth repeating since it appears people are having a tuff time getting their hands on the TomTom accessory case.
I purchased a CaseLogic PHDC-1 case from Staples (Canada). Its a near perfect fit for my Go720 which I believe is very similar in size to the 920. Its a semi hard sided case. I added a little extra padding as well.
Here is the PHDC-1 link: http://www.staples.ca/ENG/Catalog/ca...affixedcode=WW
I checked Office Depot (US version of Staples) and the closest I could find was this case. http://www.officedepot.com/ddSKU.do?...g=true&An=text
Not sure if it would fit, bring your 920 with you to the store and try it.
I'm using a Wall mart case for a Nitendo DS Lite. It fits fine about 1/2 space inside all around and a couple of pockets which I don't know what to put in yet. But the case is small and it suits the function.
Richard
I got a NDS Lite case while I was in HK ... I think it is $35 HKD (~$4 CAD).
My 720 fits prefectly in the case. :D
I bought a case in STAPLES that is marked for the TT One XL. But is seems to fit perfectly. I was right in the TomTom display
I bought a case at BestBuy,it was meant for the tt one xl,but it says can be used for the 720/920.It's leather and fit perfectly,about $50.
