I have not previously owned a GPS unit and I am on the cusp of ordering a 540 TM. I have several questions I'd appreciate some responses to. I have not seen a 540 in person, but I have been attracted to it by its screen size, reasonable cost for lifetime map updates, and that it seems to have the essential features one would want in a portable GPS unit.
A quick review of some of the posts in this forum indicates that some care should be taken after receiving the unit to back it up correctly and otherwise configure it to work properly. I am not a very technically savvy guy. As an average user type should I have any hesitancy about acquiring the 540? I am willing to read advice in a forum like this and try to follow it, but should one be reasonably tech savvy in order to avoid experiencing problems with the 540?
I would be willing to spend a little more than the approximately $200 the 540 is currently going for, perhaps $50 to $100 more, if I thought that by doing so I would acquire a demonstrably superior unit - not a much more complicated and difficult to use unit, but a unit that would handle auto navigation, points of interest, storage capacity, download speeds and other features in a superior and/or significantly more attractive fashion, and/or that is built with demonstrably better build quality and/or technology. Is there such a unit or units I should consider before pulling the trigger?
Please feel free to brag about the 540 if you think it is justified, as I am sure it will encourage me with regard to the purchase I am about to make.
Your thoughts will be very much appreciated.
Ged
Ged
