920 mount
Los Angeles, CA
Does anyone know of a powered or non-powered cigarette lighter socket flexible arm/gooseneck for the TomTom 920? I have seen one in Arkon, but, all they have is for the Garmin. Other sites have similar items, but, not the flexible arm/gooseneck and can only adjust from top to bottom and not sideways. Thank you.
Lighter Socket Mounts for TomTom GO x20, x30 series
Arkon does make one for the nearly all of the TomTom devices. Actually, there are 2 lighter socket mounts.
http://www.arkon.com/tomtom_GO_520_720_920_mount.php
The TTGO121 is a lighter socket mount that includes a power dongle. You basically plug your car charger cord into the dongle in order to keep the power flowing to your devices.
However, if you have additional 12V outlets in your car, or don't need to rely on the power, then go with the TTGO138. The lighter socket pedestal used in that mount bundle is passive, or in other words, it's just a kind of mount support that plugs into that lighter socket location.
There are some other new alternative mounts as well... such as the Sun Visor Mount or Friction Dash Mount.
Hope this helps!
Aphid2020
