Max Headroom voice
GO 720
Every couple of months I end up doing a hard reset and total reload of TTN6 for my Treo 650. It goes into super slug mode in calculating routes (long enough for the 650 to time out) and the voice develops a stutter.
Has anyone else seen a similar problem and what have you done to resolve it? I'd really like to find a quick fix.
The SD was less than half full, about .9 GB of a 2 GB device.
And yes, the voice sounds like Max Headroom during this slug mode operation.
Treo 650 with TTN6
Yes, I have the same issue. Once every month or two it craps out and I just reload from a backup. If your going on a long trip, take a backup. Another one of these little aggravating problems that everybody knows is there but TT fails to recognize. Seems with TT, most problems are "user" problems and if that answer fails then it is "not compatible with that device". It is a shame that support is so poor on such a great device/program.
Scrubber
