How do I change the direction I go from starting at home? This is my problem: I need to go south on my street rather than north. I donl want to block the north part of the road as sometimes I do need to go that way..
Just ignore the device and it will soon work out where you are going and replan the the route acccordingly, if you can add a "Via" to your route you could use that to force the route to head South but its quite a bit of messing around compared to just driving off in the direction you know best - Mike
