- Joined
- Jul 18, 2010
- Messages
- 58
- Country
- TomTom Model(s)
- Go6000, Go Exclusive that doesn't work properly
I have just bought a GO 6100 and am really pleased with it. We have a Citroënn Grand C4 Picasso, the Mk 2 version. One of the problems I have had is that there was nowhere to mount the 6100 So far it has just sat in te bottom of the centre 'glove box' and was not very satisfactory. It won't stick to the flat glove box door because it's a fuzzy felt type covering and there just isn't anywhere else for it.
SWMBO (she who must be obeyed) pointed out the 'staple' part of the closure for the glove box and I got to thinking? I decided to try a piece of perspex to slot into the 'staple' and with a bit of adjustment finished up with a perfectly stable mounting. Very simple, but very good, well think so??
The perspex is about 3/16" thick so quite stable
And bent with some careful heat it holds quite tight but is easy to fit and remove
The 6100 is easy to see and will swivel to either side
And it doesn't impede on the electric parking brake either. All in all I am rather pleased with it and although it took me a few hours to sort it would now take about 30 minutes or less now I know what I'm doing..
Edit : - I forgot to say that our C4 has the semi auto sequencial gear box and the manual version with a gear stick may be different???
