You can correct that in Map correctionsI installed the 7.15 map update, and it has added speed limits to I-64. The only problem is, it's not the correct max speed limit.
The TomTom is set to 65MPH, and the legal limit is 70MPH. Anyway to change this?
Unfortunately not.The TomTom is set to 65MPH, and the legal limit is 70MPH. Anyway to change this?
No. You can report the correct speed limit to TT, via Mapshare.Good question. In addition, is it possible to set speed limits for roads that aren't set by the map?
No! You can only report it under Map Corrections. It will not change it on your device.You can correct that in Map corrections
Unfortunately not.
I've been around. I keep an eye on the forum. But I generally only comment where I really feel passionate about an issue, where I know something that it appears no-one else does, or when I can answer a question that has gone unanswered by the rest the forum members. I always try to help where I can.Where ya been spook? Seems like you were gone for a while...
Cool, I know what you mean. I just recently figured out the subscriptions, and that has gotten me more involved.I've been around. I keep an eye on the forum. But I generally only comment where I really feel passionate about an issue, where I know something that it appears no-one else does, or when I can answer a question that has gone unanswered by the rest the forum members. I always try to help where I can.
