I think I read that the SDHC spec calls for Fat32 & that all SDHC cards should already come formatted in Fat32, out of the box.
(Although, I may have read that here...so, take it for what it's worth. IOW, do your own research! )
Hee hee!I did write that in some msgs here and elsewhere. Wikipedia was helpful to know the nitty gritty about that.
Hee hee!
I still haven't re-reformatted my 16GB card, so that TTHome can see it. But I'm really just using it as mp3 storage, which seems to work okay for playback.
R?
Interesting. If I ever find time to re-reformat this card (as per your instructions ), I'll let you know the Write results...FAT32 has a max size which exceeds the size of present SDHC cards. The problem is in the TT writing capability which varies depending on model and bootloader version on it. TT's NavCore writes when it needs to update favorites or Home location, create a route or recaclculate one, when it needs to dump a screen etc. Accessing multimedia files only involves reading. Recent bootloader versions are said to be able to write to 16GB but have not tested that myself.
I have noticed a few "quirks" in the Jukebox. Not sure if it could be related to lack-of proper formatting or not...
Any-who, some of the Genre tags are showing up corrupted. For example, 2 or 3 chapters of a 12-part "Cyberpunk" audiobook show up as differing variations of: "Cybepo???" when previously, I'd set all of their ID tags to the same values in iTunes. A few of the foreign artists are showing up wrong too.
When I check these files in iTunes, all appear fine, but iTunes may have modified their ID3 tags in a non-standard manner. No idea why, but at least everything plays correctly.
R? (thread hijacker, extraordinaire! )
FAT32 supports a max file size of 4GB, which is why you should use it over FAT or FAT16. You REALLY want the ability to put maps on your SD card, even if you don't use that feature.
Does anyone know if the 930 supports NTFS?
Could you check your info before posting erroneous information? You have it all wrong!
As for NTFS, TT uses the Linux based OS so no NTFS there.
http://en.wikipedia.org/wiki/File_Allocation_Table
Note that the max FILE size for FAT of any type is 4GB. FAT32 will let you store more on the card, but each file will still be limited to 4GB.
Here is another link on the subject to back this up:
http://windowsitpro.com/article/articleid/38803/understanding-file-size-limits-on-ntfs-and-fat.html
I accept that there are many things I may not know, so I did a quick check to verify if I was correct or not(after you said I was incorrect).
