- Joined
- Jun 4, 2008
- Messages
- 55
I take many short trips in the car, around 30 mins to 1 hour. I load up some radio shows such as Opie & Anthony (4 hours long) onto my 920 and listen a bit at a time when I am in the car. Sometimes it will take me a few days to a week to get through 1 show. However, I have noticed that when I update my 920 with mapshare and quick fix, the next time I load the GPS the audio track resets back to the beginning.
While this wouldn't be a problem if it was a 4 min song, or even if the TomTom had a halfway decent mp3 player which actually told you the amount of time in your track, the position you are currently at in your track, and a way to meaningfully skip ahead to that position, this is unfortunately not the case. The seeking function on the TomTom is horrible! Is this just on my unit or are they all like that?
With all that out of the way, is there a way for me to update my unit without losing my audio track position, or is there some better way to seek through a track on the 920 which I am not aware of? Has anyone used a Garmin or other gps with mp3? Is their player more intuitive?
Thanks in advance.
Thanks in advance.
