910 mount
The price is ok. Im just curious to see how it works out.
Im curiouse because it's a vent mount. I would hope that the vent is strong enough for the 910. I hope it doesnt vibrate like crazy.
i will let you know when it arrives & tyred it out
if it does vibrate to much i allready have a proclip
to modifie it
new ram mount arrived only 3 days from usa to uk wow
will take photos & let u all see soon
I would be interested in answers to the following questions regarding this mount.
Does the mount hold the TomTom 910 securely fixed or does it wobble?
Is there availability for the power connection etc?
Is the mount easily removable for transfer from vehicle to vehicle?
Is the mount bade from plastic or metal?
Looking at the picture you posted it seems to be an ideal solution for me.
The mount doesn't wobble for me.
You have to modify your original mount to supply the power. You can see my post on how to do this.
The 910 mount is easy to remove. Unless your other vechile has the other RAM mout parts, it won't work.
The mount is made ABS plastic and it's very sturdy. The offer metal on some parts but they are expensive.
