4 GB SDHC card on Rider 2
Hi !
I had some problems using a 4 gb sdhc card on my unit and I have been looking around to find a soulotion to this with no succes.
Now, what I did whas to Clone my 2 gb card onto the 4 gb card,
I used a program from Miray Software called HDClone, by using the TT Rider as a host and a cardreader as target it whas easy.
Now your Rider will showup as a 2 gb unit, if you check it in Controlpanel/My Computer.
To solve this I used a Partition program from Minitools called partion manager, run this and rezice your partition to 4 gb.
My TT Rider 2 is now running with no problems and I have lots of extra storage when the day come's
Reg's
akew
BigL
