via 1505 audio help
hello to all
i just bought a via1505tm so far i like the unit calculating is fast and so on.but the only issue i have is the volume is set to 100 i took off the check mark where is says link to vehicle speed and still the audio seem low compare to my old faithfull xxl-540.any fix or mod for this issue.??? thanks
In fact, many find that NOT linking the volume to speed does in fact increase the volume of the device.
i'm using in my work truck and both ways seems not loud enough like i wrote before i'm so use to the xxl-540 which has a bigger speaker housing
than the via1505tm which looks small.
BigL
