I live Canada, and there is no + signe on my phone and I can call everywhere in the world.?? Why do you want it to be removed? The + is the international/long distance dial sign. You do not need to use it in NA, but it works and you do need it everywhere else in the world...
Chip
Careful feejo! If you just don't dial the + you will have problems because you are preceding the in-country number by the country code.
If you are not dialling on a cell phone, you must do something else too. For your location (Montreal), you need to leave out the +1.
Then if the next 3 digits (area code) are not the area you are in, dial 1 (for long distance) and the remaining 10 digit number. If it is the area code you are in do not dial the 1 and you may not have to dial the area code. Different places in North America need 10 digit local dialling, some don't! Sadly the confusion continues as some places need a 1 in front of some 7 digit numbers as they are "long distance" within the area code.
For the non- North American readers who find this strange, it all stems from the fact that "local" calls are normally free here for wired phones.
Sorry I cannot be precise, it is not my explanation, it is the way the land-line dialling works here these days It is actually much easier with cell phones as your phone can dial the whole + everything number and the cell switch knows what has to be delivered to the phone system to get your call through. Unlike wired phones, you are not forced to key something (1) to indicate you realise it is long distance - chargeable.
