Maxell 653443 battery
I already tried using a Glasgow compatible battery but the connector is a little too wide and it would not plug in my unit. I need the Maxell 653443 battery. Thanks for trying to help though.
Providing the pin families are compatible, it may be easier to swap the pins between housings than to look up an unusual match. It's a bit of a trick to release them if you've not done it before, but it can be done.
You don't show a location by your name, and I assumed you had a US model TT. Could have been a bad guess on my part.
Unfortunately, the only place that pops up quickly is clear out in Taiwan:
http://www.foxlink.com.tw/_en/2_product/2pro_detail.php?ID=22
You might check with them to see if they have any distribution here in the U.S.
