XXL 550m Driving Map Display Problems
Hi Folks!
Sometimes after inputting my address and hitting "done," my XXL550m defaults to an extremely zoomed out view, and the turn-by-turn voice does not work. Zooming in only lets you get so far, and you cannot see the street view. Basically, it makes it unusable.
The location/map is in the correct area so it seems to be receiving a signal, but for some reason, it automatically goes to that view and you can't seem to go back to the 3D driving view.
It will fix itself if you turn it off and turn it back on, but that's extremely inconvenient. I just want to know what causes the problem, and how it can be fixed.
XXL550M 5
XXL550M help 1
XXL550M help 2
550M XXL vs VIA 1505M vs VIA 1535M 2
New XXL550M user question 12
using travel via function on xxl550m 1
Tomtom xxl 550m downloading map issue 1
XXL550M Won't Turn On 7
finelandscapingjandr
