Hello all,
I recently purchased a tt go 720, installed and updated the latest version of home and ran into an issue. The unit worked fine on my first trip i took. When i got home, i placed the unit on the computer docking station to look for more themes, voices etc and when it asked me if i wanna connect to my computer i clicked yes. Once i did that the gps went black. It still showed the green light showing it was charging but i couldn't power it on. If i take it off the dock and reset it, it does nothing. The only way for me to get the gps back on is to take it into the car and hook up the car charger and reset it from there. Once i do that i can disconnect it from the charger and it works like it always was but soon as i go back to place it on the dock, it goes blank and i have to repeat the above process. I have tried removing all the Home software from the system and have even tried using the version that came with the gps. Nothing helps. If there anyone out there with this similar issue and if so, any solutions? Thanks a bunch
