Hello all + need some help rebuilding SD card
London, UK
One
Hi all. Been looking through the forums but not found any advice that may may solve my problem. I have a tomtom one and a while ago my map (UK and ROI) got corrupted. I had also failed to backup (stupid I know) and tomtom support didn't really help much.
Well, I've tried all sorts the latest being copying the contents of friend's tomtom SD card (identical model + maps to mine). At some point I erased/formatted the card (on a Mac) so think I have lost all trace of the original info. Suffice to say copying from my friend's card did not work. I was met with the tomtom screen that shows the card being rejected upon start up :eek:.
I'd really like to avoid having to avoid buying a new card from tomtom and am hoping there is a way of 'saving' my tomtom.
Think I have bad news.....
Even if your friend's map is on a legitimate sd card from TomTom, you can't simply copy the contents to your card since the other map is locked to the card. In other words, you can't copy from a legitimate sd card to another and have the map work.
Thanks + that's what I thought the answer might be. I was wondering if there was a way around this through a hack or similar. After paying the device I'm really not keen on spending more money for the same thing I've already bought.
Hello from a new guy 1
Well Hello to All. 1
hello 1
Hi hello to you all 0
Hello from Yorkshire 2
Hello..... 2
I am New to this Forum Just want to say Hello !!!! 10
hello to every1 from the uk and help neede 0
smokingblack
