hi there,
i am having a spot of bother getting a custom menu to work on a
TT-XXL. the machine data is:
as far a i remember it was so easy to get the custom menu to
work. you just needed to make a new directory called
SDKRegistry and save your custom menu TomTom.mnu
into that directory and after a restart of the TT-machine you
could use your own custom directory straight away. this is
exactly what i attempted to do but the result was not the one
i had hoped for. i made a short test custom menu that is like
this:
and the result looks like this:
i can get the menu back to the original menu by deleting the
sdkregistry directory but that is not my intended solution. i
would really like to add the delete route upon arrival without
having to go through several menus to do so.
can anyone possibly think of a solution how i can get the
custom menu to work?
help appreciated.
kind regards
problem solved by starting the menu with page 2 instead of
page one:
Code:
TomTom XXL IQ Routes Edition
App. 9.061.576030.2, OS 567329
Bootloaderversion=5.5279
this:
Code:
MENUBLOCK|BLOCK_MAIN|BTM_GPS_POSITION|
MENUPAGE|TASK_PAGE1|Page 1|
MENUITEM|TASK_NAVIGATE_TO|
MENUITEM|TASK_MENU_FIND_ALTERNATIVES|
MENUITEM|TASK_PLAN_VIA|
MENUITEM|TASK_AVOID_ROUTE_LINE|
MENUITEM|TASK_CONFIRM_DELETE_ROUTE|
MENUITEM|TASK_EMPTY|
help appreciated.
kind regards
page one:
Code:
MENUBLOCK|BLOCK_MAIN|BTM_DONE|
MENUPAGE|TASK_PAGE2| This remains blank|
MENUITEM|TASK_PAGE2|
MENUPAGE|TASK_PAGE2|Page 1|
