1000 or 1005 Power Dashboard Mount
I did not see a lot of info over this Mount on the net so decided put some photographs for all to see my camera is not very good
more photos
the last photos
photo in the
it works very well with very little movement the only problem is that the magnet is very strong you need to have to 3 hands to take it off one to hold the dashboard and two hold the tomtom:heh:
I see they have included "cable drop" self adhesive pads. I've just used those (with a different mount) to tidy my cable away out of sight. Very effective.
@ dhn, canderson -et- et all......Oh no! The dreaded TomTom "nose clips"! :eek: (or were they the ear-rings?)
Looks good... I might have to find one of those...
But where does the power cable go in your pics, please cttrans? It's very well hidden!
Hi Andy I have a permanent built in power supply from the cigarette lighter and it is rooted hidden behind dashboard. I got the dashboard mount directly from tomtom and the power supply ebay.
George L
