XL 340S Screen Problem
XL 340S
So, I use my unit a lot for work. That said, the recent summer months have lent a lot of heat on the unit; it always sits on my dash.
Lately the screen has been a problem. Every key must be touched about halfway down of its original position on the screen. So, I have trouble pushing the space bar (at the bottom), or every time I try to go back, the screen will register the letter 'm', which is the key directly above it. I wonder if heat has ruined the unit.
I've seen some chatter about SD cards and updates. I can tell you I did the most recent update a few months ago:
App: 9.465.1074274.2
OS: 842337
GPS v1.20
Boot 5.5136
Any help? I don't see an SD card, probably why it was more affordable. I'm prepared to calibrate, I just don't know how. I've also considered resetting to factory, but I'm a bit hesitant.
Any help is much appreciated.
That looks familiar :rolleyes:
gardening_diva
