Using SD card on GO 600
L.A., CA, USA
GO 740 Live
How do I go about saving a map to the SD memory card on my GO 600? The internal memory is down to under 800 MB, but I've got an empty 8GB memory card.
I'd like to move the main map onto the SD card (I do not have a secondary map, but I may get one in the future).
Current map is "USA Canada" v1005.8758 (01/2018), application version 18.103.0020.311 (0) (05/08/2018).
With the newer models (such as yours), it is the MyDriveConnect application which determines if there is insufficient space in internal storage for a map. If so, then MDC tries to put a map update (or additional map) on a SD memory card--if there is one.
Personally, I use 16 gb SanDisk cards as good choices for external storage.
Yoges
