Unit won't go on
From the day I got me TomTomOne, it didn't work. I don't know why I didn't take it back. I just bought a new battery and the green light won't go on, but when I hook i up to the computer, the green light goes on. I tried all of the pressing this and pressing that nothing works. it's not the most expensive unit, none the less, I expect it to work. Can anybody help???
The green light just signifies it is getting power. When you say it doesn't go on, are you saying it doesn't power up at all or it doesn't boot past the splash screen?
How long ago did you get the unit?
When you connect to the computer, I guess the computer does not recognize it????
JoséLugo
