turn off gong sound when speeding
I have a TT One 3rd edition version 7.166 now. I used to have version 8.010.
I want to turn off the gong alarm when going over the speed limit. I do NOT have max speed checked (which turned off the sound when I had version 8.
Also, there is no Safety preferences icon in my menu with the version under "change preferences"
how do I turn off the gong alarm?
See if there is a preference option to show more menu options. If so, see if safety preference is there.
If there is no icon for safety preferences, try a pin reset on your unit.
I don't have a menu option to show more preferences and I did the reset and still have the same menu choices. There is nothing about safety preferences anywhere.
How about this? Preferences-->Voice Preferences-->Announce warnings. Uncheck it?
Try that.
nope, I don't have that either. I was able to fix it by deleting the custom TT menu I had in SdkRegistry and letting the original menu load. That brought up a safety preferences icon where I was able to turn off the gong sound (I hope). And then I loaded the custom menu back. We will see
Ah! NOW you add in the additional information (custom menu),,,,,,;)
I think you may have solved the problem. Let us know.
Jancux
