Tripmaster on Rider 2 not working
Orlando, FL
Rider 2
I have TomTom Rider 2. - App 7.901, Map N.America v835.2421.
I had not used my Rider in several weeks so I had to run an extensive update from TT, installing new version of Home and the latest map. After that was accompllished, i went on a ride using Tripmaster to log my journey. When I got home I found that Tripmaster had not recorded anything more than the origination and the destination in spite of the fact that I have logging set to drop a waypoint every 2.5 miles and every 60 degrees of course change. All of this worked beautifully before. When I went to import the GPX file into TYRE, needless to say, I was quite disappointed.
I then reinstalled Tripmaster ver. 2.5 and tried again. Same result. It does not seem that this problem is related to the Navcore 8.35 issue (though my map version suspiciously says v835?) So I did not install the additional plugin. Tripmaster has all apparent functionality it had before except it isn't laying down tracks!
Any suggestions?
Bob
ZorroNY
